First post, by Bladeforce
Hi, I was wondering as I am dual booting OSX and Ubuntu right now would it be a good idea to write a post with games compatibility in wine? More specifically I am using playonlinux as a front end for wine.
A vast majority of my owned games come from the 1996-2002 Windows gaming era (literally hundreds of games) and thought it might be a good idea to have a compatibility list (with used wine version for each game)
I understand there is a compatibility list of winehq.com but it is generally out of date and I thought having an easy list here would be handy?
There are quite a few games that work out of the box that struggle to work even in Windows
Just a thought, what do you think?
Reply 1 of 7, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
I think it would be more helpful to update the compatibility list of WineHQ.
Starting another list here or elsewhere is just starting another soon-to-be-out-of-date list. Besides the one on WineHQ does give good hints at times.
And zhen there is the matter of different compatibilities on linux and OSX....
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 2 of 7, by Bladeforce
Fair enough. My only thought is that with playonlinux you can use multiple versions of wine you require without using just the installed version as there are regressions within each engine so some games work fine with say version 1.1.36 but not with the latest 1.6-rc2. I was just thinking of putting up a list of games and corresponding wine versions that I have got working fine something that you cant do in winehq. The list would never be out of date then
Reply 4 of 7, by Dominus
DOSBox Moderator
As far as I can see, you can enter the version of Wine it worked with in the WineHQ AppDB. But I didn't create a login, only looked at Sims2 http://appdb.winehq.org/objectManager.php?sCl … ersion&iId=2633
Reply 5 of 7, by Bladeforce
Thats cool I'll stick with updating Winehq 😀
According to the nglide compatibility list requiem avenging angel dsoent work in 3dfx? Is this true because I just got it running in Wine
Reply 6 of 7, by Gamecollector
There is a bug in the nGlide with the Requiem 3dfx mode - the screen is blank. With several interface icons sometimes.
http://img824.imageshack.us/img824/835/requiem2.jpg
Maybe someday Zeus will fix this.
Reply 7 of 7, by Bladeforce
Hmm well it works fine here in Wine using nglide, been playing it for most of today too
