First post, by swaaye
Gary Donovan (of here) posted some screens and videos of his efforts to bring the card to life. Interesting stuff.
http://forum.beyond3d.com/showthread.php?t=2289&page=9 (near the bottom of the page)
http://www.falconfly.de/cgi-bin/yabb2/YaBB.pl?num=1324291379
http://www.voodooalert.de/board/index.php?pag … &threadID=19797
Someone else who's trying to revive another Rampage;
http://www.falconfly.de/cgi-bin/yabb2/YaBB.pl?num=1370739590
Ah so he finally managed to get it working eh?
Interesting stuff indeed!
Not FULLY it lacks proper drivers that unlock it's full performance.
That Quake3 Demo video looks strange. Vertex lighting? Unblended sky? How early is the OpenGL ICD for the Rampage?
wrote:That Quake3 Demo video looks strange. Vertex lighting? Unblended sky? How early is the OpenGL ICD for the Rampage?
Gary says that he had to disable several engine features via config.cfg in order to reduce the stress made to the card
That's also the lowest configuration of Rampage. The full blown version was to have had two GPU's and a separate T&L unit. That's why Rampage would have been doomed to failure even if it came out on time. It would have been far too expensive to build and would have been power hungry. The low end units without the T&L unit would have been pretty useless because T&L proved itself as a desirable feature during the DX7 era and these would have been DX8 cards so most games would have assumed a T&L unit on the card by then. They would have needed several more years of development time to fix bugs and consolidate everything onto one chip and the industry would have moved on again just like they did when V4 and V5 were released. DX9 cards would have been out by the time Rampage was ready.
While Rampage would not be my favourite as well, I would not write it off by paper specs only. Sage was not just another TnL unit. I am interested in finding out how 3dfx improved 3d upon Voodoos, as this was the only complete overhaul- after all the company accumulated more talent in the end then in the 'rampaging' beginning. However I do not believe there will ever be people able/willing to write proper driver for any complex test, even if documentation was available.
Gary's engineer contact said he figured the product was a year away from retail. This hardware is probably really bug ridden yet. I'm surprised they didn't have more driver ready considering they had real hardware done. They obviously knew all about what they were building.
Rampage probably would have gone down like VSA100 - too late and beaten by NV (and ATI by that point.) It probably would have come after Radeon 8500.
One year? Only bug I read about was the color inversion, that would be one respin with possible availability in half a year. The chip should have much less transistors then NV20-R200, so it should not be disastrous if Rampage would be slower then these.
wrote:One year? Only bug I read about was the color inversion, that would be one respin with possible availability in half a year.
Here is the one year off comment.
http://www.voodooalert.de/board/index.php?pag … 4944#post344944
wrote:That's also the lowest configuration of Rampage. The full blown version was to have had two GPU's and a separate T&L unit. That's why Rampage would have been doomed to failure even if it came out on time. It would have been far too expensive to build and would have been power hungry. The low end units without the T&L unit would have been pretty useless because T&L proved itself as a desirable feature during the DX7 era and these would have been DX8 cards so most games would have assumed a T&L unit on the card by then. They would have needed several more years of development time to fix bugs and consolidate everything onto one chip and the industry would have moved on again just like they did when V4 and V5 were released. DX9 cards would have been out by the time Rampage was ready.
Not really power hungry but very complex and expensive to produce. Very interesting though and am wondering if Nvidia used their share of samples for R&D in later projects. Did any of you see his latest video showing Rampage running DX tests? Was surprised that it ran DX9 and passed 😮
All 3dfx should have done was massively scale up their designs on the high end instead of depending on sli alone.
wrote:All 3dfx should have done was massively scale up their designs on the high end instead of depending on sli alone.
You make it sound easy. Even if such design was made, both Napalm and Rampage were pushing transistor limits of their manufacturing process, I wonder why was 3dfx transitioning so slow.
wrote:wrote:All 3dfx should have done was massively scale up their designs on the high end instead of depending on sli alone.
Everything that they done was in software long before there was any tap out and I think that they didn't invest well enough into their R&D department. The more raw compute power that there is to run the simulations the quicker the bugs can be worked out and the asic validated. Also they all should have migrated to using flip chip designs instead of the older plastic capped bga s. If they would have done that and allowed for slightly higher power consumption scaling up would have been as of a problem for any of them except for one thing. At the fab level they were still using older waver tech (most likely 200mm or less) so the larger dies would have been a big problem but they could have harvested enough of the defective dies to cover some of the costs. Nvidia's, ATI's, Matrox's, and 3dfx's designs almost all required a fully functional chip if it were to even go to market.
I did not imply problem was in their internal tools. Also I doubt they would underinvest, since their factual position was never that good and lacked cash. More likely they just canned projects and failed to capitalize on acquisitions.
