YT1 serial optical mouse
First post, by Jolaes76
Anyone having information and drivers for these?
It seems that these are NATO/government class devices (codename: TEMPEST and ZONE) specially designed against surveillance based on intercepting electromagnetic emissions. (Shielded keyboards, mice, monitors etc.)
Do these RS 232 optical mice have DOS drivers ? If not, what OSes are supported ?
"Ita in vita ut in lusu alae pessima iactura arte corrigenda est."
Reply 1 of 8, by moofree
Give cutemouse a try?
Reply 2 of 8, by Jolaes76
Cutemouse does not work. I have tried Genius, Logitech, Microsoft drivers as well.
This mouse was also sold for the MAC G3, so maybe a specially wired gender-changer is needed on the PC...? I only have simple pin-to-pin gender changers. Pls. look at the attached photos.
Reply 3 of 8, by keropi
are you sure that's not a ps2 mouse with a custom DB9 connector (going to some custom port...?)
I see 4 pins and 4 pins is all PS2 protocol needs...
Reply 4 of 8, by Jolaes76
I really have no idea. Of course, I can dissect this mouse further and electrocute it 😀 You think I should cut off the tail of a dead PS2 mouse and also cut off this connector then transplant the proper PS2 tail to the YT1? But first I should know the pinout. The donor PS2 connector end is standard, isn't it? So I only need to find out the pinout on the YT1.
Reply 5 of 8, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
The full part number of the microcontroller could help. Maybe it's an USB mouse.
1+1=10
Reply 6 of 8, by Jolaes76
Bullseye! Thanks, h-a-l-9000.
It is indeed a USB chip - CY7C63743-PC. So, for me, it is absolutely useless in DOS.
Reply 7 of 8, by Old Thrashbarg
It's not just USB, it's one of those multi-protocol chips that also supports PS/2. So if you can figure out how to wire it up, it should work just fine on a PS/2 port.
OTOH, unless there's something particularly special about that mouse, it probably wouldn't be worth the time and effort to hack a new connector on it... regular PS/2 mice are common and cheap.
Reply 8 of 8, by Jolaes76
You are right, it is not worth the effort. Now that we know what this mouse really is...
