First post, by Cloudschatze
- Oldbie
Whilst looking at AWE64 Gold cards the other day, I noticed that the RS-422 chip driving the S/PDIF output can be connected to either of two sources...
(Click the photos for larger versions.)
The circuits in green are completed by the zero-ohm resistor at R45 and R1, respectively. Moving this resistor to the pads at R46 and R2 would connect the alternate signal instead.
What's the difference, you might wonder? I have no idea. My soldering iron is out-of-commission, so I'm hoping one of the two other guys who bother with S/PDIF might be willing to do some testing... 😉
(Note the yellow point in the red circuit on both cards. This connects the output signal, whatever it is, to the AWE chip. The circuit in green has no such link back to the AWE chip, as far as I've been able to determine.)
