Reply 60 of 416, by archsan
Hmm, will check my MkII 😀
Btw, is Energizer the best brand to get? I'm not so sure about Maxell, and there's some chance of getting counterfeit "Sony"-branded coin batteries here, or counterfeit "Energizer" for that matter 😒
"Any sufficiently advanced technology is indistinguishable from magic."—Arthur C. Clarke
"No way. Installing the drivers on these things always gives me a headache."—Guybrush Threepwood (on cutting-edge voodoo technology)
Reply 61 of 416, by keropi
just checked my newly arrived MK2:
the battery started leaking from one point and there was some acid residue on the plastic holder under said point... needless to say I cleaned the area and just removed the battery all together, I don't need any settings saving 😀
Reply 64 of 416, by schlang
thx for this thread, I just pulled this sucker from my SC-55:
the one in my SC-55mkii was fine, so was the soldered one in my MU-50
PC#1: K6-III+ 400 | 512MB | Geforce4 | Voodoo1 | SB Live | AWE64 | GUS PNP Pro
PC#2: 486DX2-66 | 64MB | Riva128 | AWE64 | GUS PNP | PAS16
PC#3: 386DX-40 | 32MB | CL-GD5434 | SB Pro | GUS MAX | PAS16
Think you know your games music? Show us: viewtopic.php?f=5&t=37532
Reply 67 of 416, by TELVM
sliderider wrote:
... CR-2032 batteries ... There are Chinese sellers who have them in bulk packs on ebay for only pennies per battery. A 100 pack would probably be a good investment for almost anyone who has a lot of old hardware lying around that needs at least one of these.
Beware that much of that cheap stuff from ebay is just junk lacking even half the ~225 mAh capacity of a real CR2032 (= wil last far less).
They also love faking capacitors:
HDDs:
SSDs:
and whatever can be faked.
badmojo wrote:
... What do you guys do with old batteries? I've been vaguely aware that they shouldn't be thrown into the bin, but that's exactly where I've put them all my life. I've done a bit of research and discovered that there are numerous places near where I live which accept dead batteries to be recycled, who knew?
Whatever you do, EXTREME CAUTION when there are little children around. A button battery looks like candy to them, so they swallow it, then they die.
A tip regarding computer CMOS/RTC lithium batteries: If the system is going to spend time unplugged from the wall (and/or PSU switched off), say several months or longer, better write down/save the BIOS settings and pull out the CR2032. This will prolong battery life and prevent battery spills on the mobo.
Let the air flow!
Reply 70 of 416, by Silanda
Saw this thread yesterday and decided to check out my SC-155. Sure enough, the battery had started to leak slightly so I replaced it with a spare. No sign of corrosion that I can see on the holder.
To be honest, I wasn't even aware that CR-2032s did leak. It's a blessed relief that Roland, unlike Yamaha I believe, installed their batteries in a holder rather than using solder tabbed ones. That helps to protect the board and makes them a damn sight easier to change.
Reply 71 of 416, by dogchainx
Checked mine. No corrosion at all, kept the battery in there just for the hell of it.
386DX-40MHz-8MB-540MB+428MB+Speedstar64@2MB+SoundBlaster Pro+MT-32/MKII
486DX2-66Mhz-16MB-4.3GB+SpeedStar64 VLB DRAM 2MB+AWE32/SB16+SCB-55
MY BLOG RETRO PC BLOG: https://bitbyted.wordpress.com/
Reply 74 of 416, by badmojo
PeterLI wrote:
Good thing I check a SC-55 I got in yesterday.
Oi mate I thought you were 'retiring from the hobby'? 🤣
Reply 75 of 416, by gdjacobs
When you can't quit, isn't it known as an addiction?
Reply 77 of 416, by loktar
2.39 MiB
Thanks to this thread I just checked one I got over the weekend as well. No damage done fortunately.
Reply 78 of 416, by keropi
excellent, this one seems pretty bad - glad you caught it on time
Reply 79 of 416, by Skyscraper
I know Phil has already mentioned that the Roland SC-55st dosnt have an internal battery. I thought that it would be a good idea to post an image of the inside of the SC-55st in case someone needs to see for them selves to be convinced. 😀
This is how my bargain £16 ST-55st from Ebay looks inside, it looks alot more bullet proof than the models with displays, buttons and other fancy features! 😀
4.27 MiB
