First post, by emendelson
For various reasons, I use a .conf file with an autoexec.bat that has lines like this:
mount D ..\..\DOCS
This works perfectly. And - exactly as designed - when I give the MOUNT command later, it returns:
Current mounted drives are:
Drive D is mounted as local directory ..\..\DOCS\
etc.
My question is: since DOSBox presumably knows the full path of ..\..\DOCS\, is it possible for it to return the full path at the prompt?
Or would this require a major patch of the MOUNT command?
