First post, by subhuman@xgtx
- Oldbie
Hey guys, For the ones that have 5500s I've just noticed that you can force AA on some DOS Glide games (the ones which are dynamically linked, that use an ovl file) just by running a Batch file for the game with the following enviroment setting variable: SET SSTH3_SLI_AA_CONFIGURATION=4
I can't promise it will work on all glide2x.ovl games but so far I have tested it on Carmageddon (3dfx.exe) and it works great. The only issue is that the fps now drop down from 60. I'll post some photos later on if you want.
Hope this helps
