First post, by Pingaloka
Hello guys, I'm trying to install this game in Windows 3.1 and it is giving me quite a hard time....
There are two programs necessary to run this game...one of them being WinG, or wingset...the other one is
VFW. Both of these programs give me the following error when trying to install them:
"insufficient memory or disk space"
Running MEM /C /P I get 612k free conventional memory.
On windows I've got 65,488kb permanent memory.
Config.sys
DEVICE=c:\WINDOWS\SMARTDRV.EXE /DOUBLE_BUFFER
DEVICE=C:\DOS\HIMEM.SYS
DEVICE=C:\DOS\EMM386.EXE RAM
BUFFERS=15,0
FILES=40
DOS=UMB
LASTDRIVE=Z
FCBS=4,0
DOS=HIGH
DEVICEHIGH C:\UIDE\UIDE.SYS /S15 /D:IMESCD01
COUNTRY=034,,C:\DOS\COUNTRY.SYS
STACKS=9,256
Autoexec.bat
SET SOUND=C:\SB16
SET BLASTER=A220 I5 D1 H5 P330 T6
SET MIDI=SYNTH:1 MAP:E
C:\SB16\DIAGNOSE /S
C:\SB16\MIXERSET /P /Q
rem C:\SB16\DIAGNOSE /S /W=C:\WINDOWS
rem C:\SB16\MIXERSET /P /Q
@ECHO OFF
PROMPT $p$g
SET PATH=C:\ULTRASND;C:\WINDOWS;C:\MSIE50;C:\DOS
SET TEMP=C:\DOS
C:\DOS\MODE CON CODEPAGE PREPARE=((850) C:\DOS\EGA.CPI)
C:\DOS\MODE CON CODEPAGE SELECT=850
LH /L:1,17312 C:\DOS\KEYB SP,,C:\DOS\KEYBOARD.SYS
LH /L:0;2,4096 /S C:\VESA\VESA\S3VBE20 /INSTALL
LH /L:0;2,6352 /S C:\SHC\SHCDX33F /D:IMESCD01
LH /L:0;1,3328 /S C:\CMOUSE\CTMOUSE.EXE
LH C:\WINDOWS\SMARTDRV.EXE /L
Any ideas guys?
Reply 1 of 6, by Pingaloka
Any ideas? Maybe a clean install we do good...
Reply 2 of 6, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Slim down both autoexec.bat and config.sys to bare minimum (e.g. Don't load cd drivers...), lastdrive not z but something smaller and try again. Also, do you have enough hd space?
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 3 of 6, by Pingaloka
I need to load cd-rom as Civ2 reads from it. I do have enough space, around 1gb...I'm going to try nevertheless to slim down autoexec.bat + config.sys with minimum...
Reply 4 of 6, by Dominus
DOSBox Moderator
If the culprit are the helper programs you can copy those first from cd, reboot without cd, install and reenable cd...
Maybe 1gb is TOO MUCH for those installers...
Reply 5 of 6, by Davros
according to
http://support.microsoft.com/kb/126855
win 3.1 may have trouble with drivers larger than 504mb
Reply 6 of 6, by DonutKing
I've installed Civ 2 on Win 3.1 without issues. But that was a 486 with 8MB RAM, and a 1GB HDD. What are your system specs?
I suspect if you have a huge amount of RAM or hard disk space that the installers are checking for free space, it's returning a bigger number than the installer can comprehend and it 'wraps around' and thinks you have dramatically less space available than you really have.
