First post, by Hollister
Hollister
Offline
ok so im using a controller to play TR1 with glidos, i got everything to work except one command, lara wont walk, i assigned button 6 to be shift, which makes lara walk. If i hold down the button while lara runs she will walk, but then run again. I know the button works i have tested it, im using joytokey BTW.
