First post, by sechtor
Hello to all,
Might be useless for some,but I need so hard to have the DOSBOX working for non nokia devices, like VIVAZ U8 or SAMSUNG Innov8,and the reason is very similar with having W3.1 on your smartphones or win95 .
So, what I have at this point: 3 devices Samsung Innov8 S60v3 fp2 , Samsung G810 and Vivaz U8, all of them cracked version with no certificate validation. Dosbox_slim installed in all of them.
Tried multiple versions, last time was v0.73.
1) dependencies all installed in phone memory-no error received
2) Config file copied in the memory card
3) Dosbox_slim installed in memory card
4) Dosbox.exe changed property as system application with Xplore after install
5) Minim 78M free Ram available in each device
Result: When click on application short lag, then nothing happens.If opened by JBTaskMan , then SystemError -1 shows up, and nothing else opens up.
I look for some help and hints to solve this problem, please do not post replies about not worth working with buried phones so on 'n on, since from the start there is known and assumed we are dealing with a dead trash trying to make it walk.
Reply 1 of 1, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
You will have to contact the author of this dosbox port. it's not an official port, so not supported here.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
