First post, by F2bnp
I'm having a crazy problem here, I've never run into this before. So, let's say I want to mount my hard drive. I type:
mount C C:\
Well, as of today I guess, when I try to type that I get this:
mount C C:]
This doesn't happen outside of DOSBox of course and I even tried bringing the on-screen keyboard and got the same result. Also, some other keys like , . ' = simply won't work inside DOSBox, nothing happens.
This is on Windows 8. Any ideas?
Reply 1 of 3, by mr_bigmouth_502
DosBox has a problem with those specific keys that I believe can be traced back to SDL. There's no real way of getting around it other than using the onscreen keyboard. If you're on a laptop and you have an external keyboard attached though, you could try using the internal keyboard. This is a major problem for me on my Alienware laptop since I fried the internal keyboard and am forced to use an external usb one.
