First post, by marooned_on_mars
- Member
I was wondering if anyone might be interested in helping me with a few game recordings.
All you need is a CM unit (CM-32l, CM-64, CM-500) or any other MT-32-compatibles a way to connect to it and a way to record the output.
The thing that I want you to do is to send SysEx message to the unit, play the midi files I supply you with, and record the output and then send a reset SysEx message to the unit after each track. Nothing complicated, but depending on which game I take on, it might take some time (for long soundtracks).
Send me a PM if you're interested. Thanks in advance =)
