First post, by ratfink
- Oldbie
I have a 32 bit application in mind for my work, which would be run under 64 bit windows.
Aside of limitations deliberately built into the software itself, is it going to be limited to the max memory that 32 bit addressing can see [3.5gb or whatever] or would 64bit memory limitations apply? I have datasets that could come to 12gb, and the application is designed to run with them loaded into memory.
Anyone know?
