First post, by keropi
Hiya!
anyone here knows of a tool that runs on DOS and is able to backup/restore the WINDOWS/PROGRAM FILES/MY DOCUMENTS folders to an archive?
I am not looking for a drive/partition image tool, just something that you pick directories to be saved and it creates a backup on the disk. Long filenames support is a must too.
From what I know I can use a batch file that zips/rars/whatever said directories , but I am looking for a more elegant solution.
TIA for any info! 😊
Reply 1 of 11, by mr_bigmouth_502
I would almost suggest that a DOS-based archiving program would work, but I don't know for sure how you would go about preserving long filenames. If someone else could chime in and suggest a DOS archiver with LFN support, that would be awesome.
Reply 2 of 11, by Old Thrashbarg
I've never actually tried it, but the command-line version of 7Zip supposedly works under DOS if you use HX DOS Extender.
Reply 3 of 11, by Jorpho
PKZip added long file name support in version 2.50.
http://en.wikipedia.org/wiki/PKZIP
Presumably the Info-Zip DOS port will also do the trick.
http://www.info-zip.org/Zip.html
But I understand what Mr. Keropi means when he seeks a more elegant solution. I just can't think of what such a solution would be.
Reply 4 of 11, by Old Thrashbarg
IMO, the more elegant solution would be a more elegant batch file. With conditionals, variables, and the CHOICE command, you can do all sorts of cool shit.
Reply 5 of 11, by keropi
thanks for all your replies, it seems I must do it with a batch + LFN tsr + PKZIP , if it isn't gonna be pretty then at least it can be a format that can be opened easily 😀
Reply 6 of 11, by Joey_sw
most files required for bare-minimalist win9x to function are in 8.3 format,
you can tell by listing the file-list from win9x .CAB files, all of them're 8.3 compliant.
-fffuuu
Reply 7 of 11, by keropi
^ sure, but one also needs to archive "Program Files" , it's contents and/or even folders on Desktop , these use long file names...
Reply 8 of 11, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Of course I don't know what your ultimate goal is but a minimal BartPE Windows xp you can boot might do the trick as well. That might be way over your machine's specs though 😉
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 9 of 11, by keropi
^ my ultimate goal is to have a simple backup of my 98SE setup, so I can test a bunch of crap/drivers/hardware and not having to worry about conflicts or garbage in the system, test and then restore to a "clean" 98SE state... 😀
The machine is a p200mmx/128MB and 98SE ...
Did some tests and pkzip2.50 + doslfn works just fine, I can archive and restore LFN dirs/files in dos just fine, so I'll use that 😉
Reply 10 of 11, by bestemor
PowerQuest DriveImage runs in DOS.... 😎
Reply 11 of 11, by Old Thrashbarg
Yes it does. However, as one might guess from its name, it is a drive imaging program. And for some strange reason I get the feeling that's not quite what the OP is looking for. 😉
keropi, in the title of the thread, wrote:
Is there a DOS util that can backup/restore win9x installations? (no drive imaging)
