First post, by bristlehog
I noticed many times that older cards (like SB 1.5, SB 2.0, SB Pro, Roland LAPC-I etc.) have some specific looking components on them.
Some barrels covered with strips, named Rxx - resistors maybe?
Long rectangles (combs?) standing on their edges with many pins sticking into PCB (named RP1 on first image and IC35 on second) - what are they?
Some 'leafs' standing on two legs, named Cxx - capacitors maybe?
Weird orange drops standing on two legs, named DCx - what's that?
Black barrels with one side cut, standing on three legs and named Qx - ???
At some point all this crap disappeared from PCBs. For instance, SB Pro 2 (CT16xx) has nothing alike, while SB Pro (CT1330) is still covered with them. What was the reason for these components to become obsolete?
Here you can get fantastic wallpapers created by a friend of mine: patreon.com/Unpocodrillo
Reply 2 of 5, by bjt
Everyone moved from through-hole to surface-mount components.
They're the same components (resistors, capacitors, diodes, transistors & integrated circuits), they just look different.
Overall component count decreased over time too due to integrated circuits doing more and needing fewer support components.
http://en.wikipedia.org/wiki/Surface-mount_technology
Reply 4 of 5, by keropi
correct, these are resistors
resistors again
ceramic capacitors
tantalum capacitors
transistors
like bjt said, the packaging of components changed but they are still the same... capacitors/resistors/transistors/etc
Reply 5 of 5, by badmojo
It's really intereting stuff I think. As a kid I spent many happy hours with my cousin who had an electronics kit, allowing us to make simple things that went beep or flashed an LED. My father taught me how to solder and I've done countless simple jobs over the years, so my bareing wires and soldering skills are passable, but I'd love to be able to do complicated things. I'm really impressed with people who have enough know-how to recap a PSU for example, or determine which components need to be replaced on a sound card and do the work themselves.
Just one of the many reasons I like playing around with old hardware; there's always something new to learn!
