First post, by pkw4
hi all 😁
i have a pentium 2 350mhz 100fsb, the board i have is a 440lx chipset for 66mhz fsb only, when cpu is installed it runs at 233mhz (can oc to a max of 290mhz@85fsb but will kept it at 233mhz). The thing that is on my mind is will this run ok/safe with the cpu needing a lower voltage to the older pentium2 klamath core? the board is a QDI Legend V and is jumperless design with no voltage control.
thanks in advance..
