First post, by Kahenraz
One of the features of my MM-401 clone is that, according to the manual:
Runs on any PC at any speed, including PC/AT/386/486’s/Pentiums
Which of the original Roland MPU-401 cards have problems on newer processors? And what kind of behavior is exhibited?
Reply 1 of 8, by Mau1wurf1977
I can tell you that the MPU401AT works fine in Super Socket 7 machines.
Apart from that, MT-32 is really ideal for games that run well on a 386SX and 386DX. Anything newer generally used General MIDI.
My YouTube channel
Reply 2 of 8, by Cloudschatze
Assuming the motherboard runs a "standard" ISA bus rate, none of Roland's MPU-401 variants should exhibit timing issues. With a non-standard bus rate, they all can and will, including the MPU-401/AT. If an MT-32 is connected, timing-related issues can manifest as "Excl. Checksum Error" messages being displayed on the LCD.
In addition, other sorts of issues can occur when using an MIF-IPC card in an AT-class or newer system.
See this thread:
http://queststudios.com/smf/index.php/topic,1926.0.html
And specifically this post, for a problematic example:
http://queststudios.com/smf/index.php/topic,1 … 3.html#msg23653
Reply 3 of 8, by keropi
I can also verify that the LAPC-I and MPU-IPC-T don't have a problem running in a p1/200mmx machine
Reply 4 of 8, by Kahenraz
I'm actually running it on a Core 2 Duo at 2Ghz. Any ideas on what a good test would be? 🤣
Reply 5 of 8, by Mau1wurf1977
Well your GAMES will likely cause issues 😀
Try Monkey Island and Wing Commander.
My YouTube channel
Reply 6 of 8, by Kahenraz
No problem with playing the Monkey Island and Wing Commander intro music on the MT-32.
Reply 7 of 8, by Mau1wurf1977
What settings do you use on your mainboard? FSB? Multi? Caches?
Wing Commander should be unplayable.
My YouTube channel
Reply 8 of 8, by Kahenraz
At normal speed, yes, it's blazing fast! To fix that I use a slowdown utility.
