First post, by Kahenraz
Spent a couple of hours tonight and a lot of head scratching to fix this one.
Fix added as attachment for a local vogons copy.
SYMPTOMS
When you start Windows for Workgroups version 3.11, your system may
stop responding (hang) at the password dialog box or in Program
Manager if you set your password to null during Setup. The WG0974 disk
included with this Application Note contains a new virtual keyboard
driver that corrects this problem for the following computers:
Manufacturer | Model(s)
Acer America | Pac 150, 1100LX Portable
Advent | Machines using Blue Lightning chip set
Corporation |
Ambra Corporation | Machines using Blue Lightning chip set,
| including B466DL, B466TL, D466DL, D466TL, and
| D466BL
AST(R) | Ascentia 900N 486/75 laptop
Compaq | All Aero(TM) machines, LTE Elite(TM) 4/75CX
Compudyne | Specific models unknown
Crystal Data | 486 machines
Systems |
DEC(TM) | 316 SX, 320 SX
GRiD(R) Systems | 320S with Tandy(R)/Phoenix BIOS V 1.10
GTSI | 0783 486 SX/25 (SFA and desktop)
IBM(R) | Valuepoint PS/2(R) 450TX2/D machine types
| 6382, 6384, and 0783
Tandy | 2500 SX/20, 2500 SX/25, 2500 SX/33, and 4020
Twinhead | 486/33, Superset 590 386/25
Victor | 300 SX/33 and 400 SX
NOTE: Machines manufactured by Compaq after April 1, 1994, that
ship with Windows 3.1 come preinstalled with a virtual keyboard
driver (VKD) that corrects this problem. Upgrading to Windows for
Workgroups 3.11 leaves this VKD in place and allows the keyboard to
work properly. However, if you install Windows for Workgroups 3.11
to a new directory, the keyboard stops functioning. If you perform
such an installation, you must manually install the new VKD.
CAUSE
The keyboard controllers in these machines generate unnecessary
interrupts each time a key is pressed and released. The keyboard stops
responding because the Windows for Workgroups 3.11 VKD, unlike the
Windows 3.1 VKD, does not ignore these extra interrupts.
    wg0974.exe
    27.2 KiB
    240 downloads
Reply 1 of 2, by kleung21
8 years later and this is still relevant. Exact thing happened to my Acer 1100lx. Ended up installing windows 3.11 (not workgroups).
The bug seems to be in wfw
Reply 2 of 2, by audiocrush
Hi,
Add the IBM PS/1000 Blue Lightning to the list.
Happened here as well.
https://www.nerdsh.org/ - my blog, a bit neglected though
https://www.youtube.com/channel/UChsU6woi3lhLhtT_ILbSCCw - Some videos of mine
