First post, by truth_deleted
With gulikoza's hint, I was able to set the gamma higher in DOSBox while running 3dfx emulation; this works in 95 but not for statically linked glide titles (for example, EF2000). I haven't tested this for dynamically linked 3dfx/DOS titles. Attached is the minor patch.
The above is tested in a Windows host, but it should work in Linux and others. The downside is the gamma setting may be retained on exiting DOSBox. In this case, it can be set back to the default via the display setttings, or I've used ATI Tray Tools.
Also, I added another patch to disable (many) dithering functions in the Voodoo1 emulation. This is experimental, but the emulation seems a tad faster and better; experts here will know the importance of dithering in 3dfx games.
Edit: 3dfx gamma patch appears stable; however, the 3dfx dithering patch is not stable and not recommended.
Reply 1 of 2, by leileilol
Wouldn't this work better as a hlsl/glsl postprocess shader? 😉
Also consider the 'filtering' which is an identifying characteristic to the Voodoo appearance.
long live PCem
Debian's fucked
Reply 2 of 2, by truth_deleted
I agree. 😀 The attached gamma correction is intended as a temporary measure.
The "no color dithering" doesn't show any recognizable changes to the screen, at least to my eye. However, it should save some CPU cycles and the emulation seemed a bit smoother. It would require testing and verification of the placement of all dithering functions.
