First post, by Jorpho
I just noticed this: starting DOSBox with the "-printconf" switch causes DOSBox to exit immediately. I guess it's supposed to do that, but it makes the switch entirely useless: even if you start DOSBox with "-printconf -noconsole", DOSBox will just create stderr.txt and stdout.txt and delete them immediately.
Also, starting the SVN version (ykhwong's build) with "-printconf -noconsole" results in the creation of stdout.txt with just one line:
tried creating \\dosbox-SVN.conf. but failed
Reply 1 of 6, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
So it seems it's useless on Windows not on every other OS 😉 (mostly because it deletes stderr/out on Windows)
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 3 of 6, by Jorpho
All right, I tried the EmuCR build. However, it doesn't seem to use stdout/stderr in the same way as ykhwong's build. When I launch it from a command prompt window – even without any switches – the title of the command prompt window changes to "DOSBox Status Window" and all the DOSBox status messages are displayed in that window. When I launch ykhwong's build from the command prompt, a new, separate DOSBox Status Window opens, and the command prompt window remains free. Does that make sense?
I think the way the EmuCR build handles things is probably much more useful, though I haven't the slightest idea what the difference is.
Reply 4 of 6, by Dominus
DOSBox Moderator
The way emucr does it is the "correct" way, as it happens on Linux and OS X (after a fashion). But on Windows it is more useful to redirect the output to text files for the users to find afterwards.
Reply 6 of 6, by Dominus
DOSBox Moderator
if it's done correctly the files should be left behind (but get overwritten on next start of dosbox)
