SNK S3 Graphics Card Question
First post, by ReeseRiverson
I ended up having a couple of these cards, a while back, and at least have one, and I am wondering if anyone knows anything about it. Best to my knowledge it has a S3 Virge/GX chip. And I can easily obtain Windows 3.1 drivers for it. However I don't know how much VRAM it has, let alone what the features this board provides. 😦
Reply 1 of 49, by keropi
that seems to be a part of an arcade machine or something... have you tested it? does it output a VGA signal?
🎵 🎧 SoundVision PRO,MK1869 , PCMIDI MPU , OrpheusII , Megacard and 🎶GoldLib soundcard website
Reply 3 of 49, by ReeseRiverson
It came out of a machine I had that ran Windows 95, and a 200MHz Pentium Pro.
It uses the same exact drivers my S3 Virge/DX uses on Windows 3.1 with out issue.
Reply 4 of 49, by keropi
interesting... it's kind of ugly 🤣 and half of the card is unused in a normal pc but if you plug it in and run Scitech Display Doctor it will report the amount of VRAM accurately
Reply 5 of 49, by bjt
I wonder what the empty space at the back is for? Some kind of custom ASIC?
Reply 6 of 49, by sliderider
Dual Virges maybe? 🤣
Reply 7 of 49, by ReeseRiverson
I always wondered if that was for a dual graphics card setup like the 3DFX cards could do. 🤣
Reply 8 of 49, by Stiletto
There's at least one Virge/DX card out there that uses dual GPUs to support multiple monitors. Can't find a picture at the moment, here's the thread.
http://www.3dfxzone.it/enboard/topic.asp?TOPIC_ID=1814
[EDIT] Another:
http://www.alinc.com/stb-mvp-dual-virge-dx-gr … 269489-001.html
I'll ping my arcade contacts but this might have only been a SNK-branded video card for the Japanese market, meant to be installed to upgrade a PC. At the moment, I'm not aware of any SNK ArcadePCs...
do the Fandango!" - Queen
Stiletto
Reply 9 of 49, by Stiletto
Verification needed: how many pins is that edge connector, please? Also, what's the reverse side look like?
[EDIT] Also, the PCI bracket... VGA out, S-Video out, RCA video in, RCA video out... audio in, audio out? Is that what I'm seeing?
If so, that means the edge connector is likely a video/VESA feature connector. Our current guess would be for an MPEG daughtercard.
Stiletto
Reply 10 of 49, by ReeseRiverson
There's only one 3.5mm jack. What you see next to it, is a potentiometer, so if that jack is for audio, then it may be a volume control? Definitely does have an S-video style connector, two RCA connectors... they didn't appear to be marked.
However I'll get you the details when I get home where it's at. More pictures to go with it. 😉
Reply 11 of 49, by Stiletto
Current thinking:
"They either licensed their logo to someone else or they got someone to stick their logo on some cards to make some quick money."
In other words, a simple PC upgrade kit.
I'll wait to hear from my Japan contacts, but I don't think it's anything other than this. Still, perhaps a driver package still needs to be found that supports all the features of the card.
[EDIT] Here's another, different SNK-branded card. Says it's made by Canopus.
http://www.retropc.net/yasuma/V2/PC/GA/PCI/neo_ac_sys.html
http://www.d1.dion.ne.jp/~pdc/webcache/videochips/neo.html
Stiletto
Reply 12 of 49, by keropi
I don't think that's a simple pc upgrade vga... all those transformers / big caps on the upper right side serve something else... probably the hardware that plugs on the pins on the top... these things have no place on a pc virge card 🤣
Reply 13 of 49, by ReeseRiverson
Unless it's got an amplifier for the audio output, if that's what the 3.5mm jack is for...? Just my thinking. 😳
I suppose I could try the video out jacks to see if they actually do anything with the basic S3 Virge drivers I have.
Reply 14 of 49, by keropi
I think that some audio/video card connects to the expansion above and activates the extra outputs... but test it and see what happens 😀
Reply 15 of 49, by sliderider
Not sure that is an arcade card. SNK's arcade machines basically used Neo Geo hardware with a multi-cart adapter.
Reply 16 of 49, by Stiletto
Yes. I know. 😀
- Stiletto
- long-time MAME project assistant/researcher
- all your base are belong to me
Stiletto
Reply 17 of 49, by Stiletto
According to this page, these cards (S3 Vision 964-based, but it probably applies to your S3 Virge/GX card as well) were probably intended for development machines, and were leaked to the market by the time of SNK's bankruptcy. (April 2001).
Stiletto
Reply 19 of 49, by leileilol
No wonder they've stuck to 2D........ 🤣
long live PCem
Debian's fucked
