First post, by RrnR
I have installed DOSBox and it looks pretty robust. However my main reason for installing was to enable me to run some batch builds that depended on some MS-DOS 16 bit apps that it is not worth porting to 32-bit. These batch files run fine on Windows XP, but I have just ported to a WIndows 8 64-bit system and the only way I can run the 16-bit apps in these batch builds is to run inside a DOSBox.
However, DOSBox doesn't seem to implement the syntax construct:
if <condition> (
blah
blah
else (
blah
blah
There are other batch "features" I use like delayed expansion also that probably won't work though I haven't investigated these . Is these a way to handle these (apart from rewriting the batch files and polluting them with GOTOs)?
TIA
R
Reply 1 of 3, by Qbix
Rank DOSBox Author
DOSBox Author
Not sure which command interpreter you used in the past , but not many DOS supported if else constructs with brackets.
So yes goto are the way to go.
Water flows down the stream
Reply 2 of 3, by DosFreak
DOSBox emulates DOS not the Command Prompt.
You can try loading 4DOS 8.0 in DOSBox http://www.4dos.info/sources.htm
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
Reply 3 of 3, by Jorpho
Indeed. Depending on the nature of the programs, you might be able to interpret the batch file using the Windows command prompt and substitute DOSBox (with the appropriate parameters) for the name of the executable.
