First post, by truth_deleted
truth_deleted
Offline
x86 platforms may compile dosbox to use the dynamic-x86 (faster core) or the dynrec core. However, in compiling dosbox-SVN+3dfx_patch with the dynrec core there are a couple of errors which also occur in compiling the 64-bit linux version (credit to Ykhwong). That web link has information to bypass the errors as shown below.
Patch #1:
--- src/cpu/core_dynrec_orig.cpp 2014-02-14 06:30:42 -0500+++ src/cpu/core_dynrec.cpp 2014-02-14 06:14:32 -0500@@ -331,4 +331,10 @@ void CPU_Core_Dynrec_Cache_Close(void) {cache_close();}+void CPU_Core_Dyn_X86_SaveDHFPUState(void) {+}++void CPU_Core_Dyn_X86_RestoreDHFPUState(void) {+}+#endif
Patch #2:
--- src/cpu/core_dynrec/decoder_basic_orig.h 2014-02-14 06:30:16 -0500+++ src/cpu/core_dynrec/decoder_basic.h 2014-02-14 06:33:09 -0500@@ -140,13 +140,13 @@ static bool MakeCodePage(Bitu lin_addr,Creturn false;}if (handler->flags & PFLAG_NOCODE) {- if (PAGING_ForcePageInit(lin_addr)) {+ // if (PAGING_ForcePageInit(lin_addr)) {handler=get_tlb_readhandler(lin_addr);if (handler->flags & PFLAG_HASCODE) {cph=(CodePageHandlerDynRec *)handler;return false;}- }+ // }if (handler->flags & PFLAG_NOCODE) {LOG_MSG("DYNREC:Can't run code in this page");cph=0;
