First post, by rhester72
Both "offical" DOSBox and various patched versions exhibit similar behavior.
I have a number of floppy images (type IMA, extension IMG, not compressed) - some 160KB 5,25" SSSD, others 360KB 3.5" SSDD (specifically, Infocom "booter" images).
Interestingly, if I try to boot them with DOSBox, they boot and work fine. When trying to mount with IMGMOUNT via:
IMGMOUNT a test.ima -t floppy
DOSBox indicates a good mount, but the console reports:
Loaded image has no valid magicnumbers at the end!
Mounted FAT volume is FAT32 with 613554067 clusters
(Oh, I hope not! 😀
I've tried going as far as passing appropriate CHS values to IMGMOUNT with no success.
I'm trying to get this working because ZorkTools (a very old DOS Infocom booter manipulation/conversion app) requires the "floppy drive" to be readable and writable at the sector/physical level.
Thoughts/suggestions?
Rodney
Reply 1 of 6, by Gamecollector
Install virtual floppy drive.
Mount.
Use this drive in DOSBox.
Reply 2 of 6, by rhester72
I think I'm starting to better understand the nature of the problem. The Infocom booters do not have a filesystem _at all_...it isn't FAT or anything else, it's entirely custom.
I've mounted a raw 160KB Infocom disk image under ImDisk, which Windows of course immediately wants to format (and I declined 😉.
If I MOUNT it under DOSBox as drive A (-t floppy), it again gives the impression of mounting OK, but attempts to run ZorkTools against it results in:
Insert Infocom game disk in drive A.
press any key to continue....
undefined error occurred
while reading drive A
track 1 sectors 1 - 8
disk operation aborted.
Is there any way to get DOSBox - through native or external means - to see "floppies" without a FAT filesystem and be able to interact with them on a sector basis? (I imagine this is common to many disk protection mechanisms of the era.)
Rodney
Reply 3 of 6, by ripsaw8080
Rank DOSBox Author
DOSBox Author
DOSBox wants a recognizable filesystem on IMGMOUNTed floppy images when they're mounted. Perhaps if you boot real DOS it won't complain about no filesystem until you try to read the disk with some command.
Reply 4 of 6, by rhester72
I think you're on to something! Using this method (with FreeDOS), I get:
Using partition 0 on drive; skipping 63 sectors
Mounted FAT volume is FAT16 with 64439 clusters
in the console after BOOTing a 2GB FreeDOS image on C and having IMGMOUNTed a 160KB floppy image on A, and
Unable to find the code which sets
the top of memory address for the game.
This disk is probably not an INFOCOM
game. IVD aborting...
from ZorkTools. I consider this a major step forward because I'm getting precisely the same error above when trying this from VirtualBox, which I've been made to understand _should_ work.
I'll keep digging at it - thank you for the tip!
Rodney
Reply 5 of 6, by rhester72
It looks like the root cause of the issue is that the original Infocom booters deliberately malign the first 8 sectors into 4 1024-byte sectors, and use the bootloader to reprogram the FDC to deal with this at load time. I doubt ZorkTools will ever work properly outside of actual hardware. Thanks to all who contributed!
Rodney
Reply 6 of 6, by Stiletto
In DOSBox, you are surely correct.
In other emulators... Sure it will work (if not now then at some point), you'll just have to test it under actual PC emulators like PCem or MESS instead of DOSBox. But... as this is the support forum for DOSBox, can't really discuss that more here in this subforum. But try "PC Emulation" here in "Eddie the Shipboard Computer", or MESS's forum elsewhere. 😀
do the Fandango!" - Queen
Stiletto
