First post, by Balderich
Is it possible to run DosBox twice at same time? I need two instances of it.
Reply 2 of 6, by Balderich
I did. But it is not what I need.
I would start two diffrent Instances with diffrent settings.
Instance 1 should listen to COM1 and Instance 2 to COM2.
If I start these 2 instances (2 Copys of DosBox with diffrent setting in the "DOSBox 0.74 Options") only one of them starts... but this starts twice 🙁
So I can run two instances, both listen to COM1 or 2 Instances listen to COM2.
I'd also tried to use one DosBox Installation and as sencond Instance the Portable version, but same issue.
Any Idea?
Reply 4 of 6, by IIGS_User
Balderich wrote:
Got the issue. Both instances starts the C:\Users\USERNAME\AppData\Local\DOSBox\dosbox-0.74.conf
But how to get rid of it?
-conf
Klimawandel.
