First post, by rodimus80
I have attached a video that shows the problem in action when playing Indiana Jones and the Fate of Atlantis CD. After I run the TEST-SBP.EXE. As you will see in the video, 2-Operator FM Music and 4-Operator FM Music work fine. But when I click on Digitized Sound, nothing happens. I then run Doom 2 which works correctly. I have also posted my AUTOEXEC.BAT. I am using the 2 Install Disks located at VOGONS Driver Library.
DOS 6.22
SB Pro 2 (CT1600)
http://www.youtube.com/watch?v=NcZGaDcM83Q&feature=youtu.be
(Sorry about the B/W. I am using a ATI 3D Rage Pro II to a Hauppauge 1600 via S-Video. The error is probably cabling. And I do not know how to embed youtube videos in this forum. If someone could also answer that then that would be great too!)
SET SOUND=C:\SBPRO
SET BLASTER=A220 I5 D1 H5 P330 T6
SET MIDI=SYNTH:1 MAP:E
@ECHO OFF
C:\DRIVERS\MOUSE\CLOAKING.EXE
C:\DRIVERS\MOUSE\MOUSE.EXE
PATH=C:\DOS
GOTO %CONFIG%
:EMS
LH C:\DOS\MSCDEX.EXE /D:MYCDROM /E
GOTO END
:EMSNOCD
GOTO END
:XMS
LH C:\DOS\MSCDEX.EXE /D:CDROM /E
GOTO END
:XMSNOCD
GOTO END
:MIN
GOTO END
:MINNOCD
GOTO END
:END
Reply 2 of 6, by rodimus80
5u3 wrote:
This BLASTER setting is for SB 16, not SB Pro. Try A220 I5 D1 T4 instead.
Just tried that. Now when I start Indiana Jones and the Fate of Atlantis I just get a black screen. Unable to close or restart. Have to manually push reset. And Digitized Sound does not work in TEST-SBP.EXE Test Menu.
Reply 3 of 6, by bristlehog
What if something is wrong with your IRQ and DMA settings? Are you sure the card IRQ, DRQ and DACK jumpers are set the right way?
Hardware comparisons and game system requirements: https://technical.city
Reply 4 of 6, by rodimus80
Seems to work correctly so far for the following games: TIE-Fighter CD, X-Wing CD, Tomb Raider, Doom II. I checked www.lucasarts.com to see if there are any updates and there are for my setup. Unfortunately the FTP seems to be down.
Reply 5 of 6, by Robin4
Iam guess this is what your looking for:
I dont know if its the right one..
http://www.gamefront.com/files/service/thankyou?id=902426
http://www.gamefront.com/files/901496
FATECD.ZIP
    indy4fix.zip
    84.94 KiB
    27 downloads
Reply 6 of 6, by rodimus80
Robin4 wrote:
Iam guess this is what your looking for: […]
FATECD.ZIP
Big thanks!
