First post, by The_Bish
Hey,
I'm new to DOSBox so sorry if I'm asking a really basic question that's been covered a million times before but I can't find the answer and hoping someone can steer me in the right direction...
I've been running championhip manager 97/98 through DOSbox and when it's come to games they've been running a bit slow so I've been pressing ''Alt-F12'' to speed it up, which was working just fine. However now it has stopped working, as has ''CTRL-F10'' to release the mouse. If I hit ''ALT-ENTER'' then it still toggles between full screen, and also the game itself is responsive to the keyboard...
Does anyone know what might be causing this or the solution? I'm assuming i've probably accidentally set some kind of lock...
Hope someone can help!
Thanks
Reply 1 of 2, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Have you messed with the mapper or are you loading s custom keymap?
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 2 of 2, by The_Bish
Errrr, I'm not sure what the mapper is, and I haven't loaded any custom keymaps. I haven't tinkered with anything whatsoever...
On a positive note though, it seems to be working fine today, no idea what caused the problem, but either way it seems to have gone away!
Thanks for your help anyway
