First post, by StefSOFT
Hello guys and girls,
I'm trying to make a simple shell script which runs a dosbox instance and a custom configuration file.
The script currently looks like this:
#!/bin/bash
BASEDIR="$( dirname "$0" )"
cd "$BASEDIR"
open -a DOSBox --args -conf conf/preferences.conf
When running the script DOSBox opens, but still uses the preference file from ~/Library/Preferences/DOSBox 0.74 Preferences.
The last command in the script I got from this wiki page: http://www.dosbox.com/wiki/DOSBox_and_Mac_OS_X
The .conf file is a copy of the original preference file, with full screen changed to 'true' and some custom autoexec commands.
Anybody knows what I'm doing wrong?
Goal of this exercise is to make dosbox run with all the contents in it's own folder, so I can create multiple folders for different games and run them with a simple double click in OS X.
Reply 4 of 5, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Damn my answer got lost ;(
I wanted to point out http://www.dosbox.com/wiki/Mac_OSX_Advanced which has my AppleScript for doing that nicely 😉
You have your special configs in one folder and yo choose via doubleclick in the AppleScript GUI.
But your problem might be solved by entering the full path to the conf. Since you are starting from an App bundle relative paths get confused at times (hence why your other solution works)
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 5 of 5, by StefSOFT
The goal indeed was to make it relative to only the game/dosbox folder. In that folder I created the start.command shell script, I'm able to run the relative conf file and mount the relative c-drive and cue file. Everything is now working as expected. Thanks for the link though, I will read into that.
