First post, by ratfink
I recently got a 286 motherboard [thanks to keropi 😉], I was hoping someone could give me some guidance.
Memory: the board will accept 256kb and 512kb sticks of ram but doesn't seem to recognise 4mb sticks. Is that a 286 limit or the chipset [doesn't matter for the 286, I mainly want to check my ram hasn't gone bad].
Hard drives: I've put a Winbond serial/parallel/FDD/HDD card in it, the floppy drives appear to be picked up [the usual noises and LEDs coming on at the right times during boot] but when I attach a hard drive I get an error. The IDE cable is correctly oriented [machine won't boot with it the wrong way round...] and I have the correct geometry set in the bios. Testing with 10gb and 4gb hard drives, known working. In each case the 286 seems to lose the 5.25 inch floppy drive and report a hard drive controller failure [10gb] or C: failure [4gb]. The 4gb drive I am sure worked with this Winbond card in a 386 previously along with 2 FDDs, so it shouldn't be incorrect jumpers on the Winbond card.
