First post, by taiken7
Just a short note to see if anyone else is making progress,
So far I've implemented the registers, but have yet to
gain access to the VGA memory space from the HGC space.
The graphics are chained like "mode-X" but with only 1bpp
Please let me know if the colour "bands" looks correct.
Also if anyone knows where I can tweak INT-11 to report
a HGC instead of VGA (or HGC specific software),
please list them!
A "screenshot" of work in progress:
    22.91 KiB
    Xenon2 intro
Reply 2 of 10, by taiken7
Was there a correct colour scheme?
Call it nostalgia, but my days lack monochrome "green"
(easy enough to program any other mono scheme, such as amber or grey)
Mixing 4 colours looks quite impressive too.
Resolution - 720X350 pixels and a beautiful 9x14 font set.
(I think VGA default textmode is 640x400 with 8x16 fonts)
(Still working on fonts..)
Reply 3 of 10, by Harekiet
Rank DOSBox Author
DOSBox Author
Default vga is 720x400 with 9x16 fonts.
Current CVS already has some support for hercules graphics mode though and you can further help detection of it with setting the machine variable in the config file
    2.93 KiB
    hmm why isn't it showing the pictures here though
Reply 4 of 10, by taiken7
Thanks Harekiet,
Have the second graphics page up, not able to CVS so here is the
change you need to make to vga_misc.cpp:
-/* Hack around like it looks we are in 0xb000 segment */
- vga.gfx.miscellaneous=(vga.gfx.miscellaneous & ~0x0c)|0x0a;
+/* Hack so it it looks like we are in 0xb000 or 0xb800 segment */
+ if (val>>7) vga.gfx.miscellaneous=(vga.gfx.miscellaneous)|0x0c;
+ else vga.gfx.miscellaneous=(vga.gfx.miscellaneous & ~0x0c)|0x0a;
Now you can run any other hercules apps that dont make use of bios calls
(still finishing those).
    11.64 KiB
Reply 5 of 10, by Harekiet
Rank DOSBox Author
DOSBox Author
Did it slightly different now so you don't have the black lines over the screen. Always thought the hercules had only 2 8kb pages in the 0xb000-0xb7fff range. I should read the documentation better 😜
    7.16 KiB
Reply 7 of 10, by Qbix
Rank DOSBox Author
DOSBox Author
i think you are free to choose your own pallete (at least if you're coding it)
Water flows down the stream
Reply 8 of 10, by taiken7
Thanks Harekiet, that re-write looks much better than my efforts.
AND pictures look much better without the scan lines!
Now there still seems to be one last bug,
(looses visiblity (ie wrong page) shortly after your screenshot);
I'll try comparing sources, I think the 'hercules mask' is sticking ...
**Edit:
vga_misc.cpp: Line 225
if (vga.herc.enable_bits & 0x2) {
mask|=0x80;
-- VGA_SetupHandlers();
vga.herc.mode_control=(vga.herc.mode_control & ~mask) | (val&mask);
++ VGA_SetupHandlers();
break;
Reply 9 of 10, by Harekiet
Rank DOSBox Author
DOSBox Author
hehe yeh it sets up the new handlers before updating the value, i'll give it another write and lose the mask thingie a bit.
--edit
Hope it works correctly now 😀
    10.61 KiB
Reply 10 of 10, by taiken7
Bit of a challenge this one provided, hopefully its now stable:
This code Fixes INT10-function 3 (Video Scroller support):
add the following to INT10_CHAR.CPP
(Somewhere just below the #includes ..)
static INLINE void CGA2_CopyRow(Bit8u cleft,Bit8u cright,Bit8u rold,Bit8u rnew,PhysPt base) {
Bit8u cheight = real_readb(BIOSMEM_SEG,BIOSMEM_CHAR_HEIGHT);
PhysPt dest=base+((CurMode->twidth*rnew)*(cheight/2)+cleft);
PhysPt src=base+((CurMode->twidth*rold)*(cheight/2)+cleft);
Bitu copy=(cright-cleft);
Bitu nextline=CurMode->twidth;
for (Bitu i=0;i<cheight;i++) {
MEM_BlockCopy(dest,src,copy);
MEM_BlockCopy(dest+8*1024,src+8*1024,copy);
dest+=nextline;src+=nextline;
static INLINE void CGA2_FillRow(Bit8u cleft,Bit8u cright,Bit8u row,PhysPt base,Bit8u attr) {
PhysPt dest=base+((CurMode->twidth*row)*(cheight/2)+cleft);
attr=(attr & 0x3) | ((attr & 0x3) << 2) | ((attr & 0x3) << 4) | ((attr & 0x3) << 6);
for (Bitu x=0;x<copy;x++) {
mem_writeb(dest+x,attr);
mem_writeb(dest+8*1024+x,attr);
dest+=nextline;
............ Then replace the following ...........
case M_TEXT16:
TEXT_CopyRow(cul,clr,start,start+nlines,base);break;
--// case M_CGA2:
++ case M_CGA2:
++ CGA2_CopyRow(cul,clr,start,start+nlines,base);break;
case M_CGA4:
... AND ...
case M_TEXT16:
TEXT_FillRow(cul,clr,start,base,attr);break;
--// case M_CGA2:
++ case M_CGA2:
CGA2_FillRow(cul,clr,start,base,attr);break;
case M_CGA4:
CGA4_FillRow(cul,clr,start,base,attr);break;
Now you can play King's Valley (CGA/Tandy)!
King's Valley
