ISA sound card with windows games
First post, by xTamx420
How well would an ISA sound card work with later windows games? I'm having trouble with my PCI sound card running doom and dark forces which are dos games. If I got an ISA card, say an AWE64, would it work well with my newer games like mech warrior 2? I would like one card that does both dos and windows games well if that's possible.
Reply 1 of 20, by leileilol
AWE64 has DirectSound support so yes, it in theory should work with anything that uses that API, which means other Windows games much much more modern than Mechwarrior 2.
The real problem are some of the flakier, cheaper or exotic ISA sound cards that may not have Directsound support ever, like some of the OPTi MSS cards before 928, and maybe some GUS or two... in that case you'd most likely get delayed or scratchy sound, and that's if you're fortunate on having any sound at all 😀
Reply 2 of 20, by Mau1wurf1977
Have good experiences with the AWE64 for early games. But you will miss out on A3D and EAX which some of the early games use.
My recommendation is to go with a Vortex 2 PCI card. It has excellent DOS support.
My YouTube channel
Reply 4 of 20, by Stojke
YMF754 has genuine OPL3?
Reply 5 of 20, by RacoonRider
How about YMF719? I am in desperate need of free PCI slots and I thought I could swap Vortex 2 for YMF719 to install some cooling for my Voodoos.
Reply 6 of 20, by BaronSFel001
I am combining AWE64 Gold with Aureal SQ2500 for greatest versatility. The only issue I have come across so far is the AWE64 causing address conflicts with my Roland LAPC-I.
System 20: PIII 600, LAPC-I, MK1869 Xtreme, Voodoo3, SQ2500, R200, 3.0-Me
System 21: G2030 3.0, X-fi Fatal1ty, GTX 560, XP-Vista
Retro gaming (among other subjects): https://baronsfel001.wixsite.com/my-site
Reply 7 of 20, by Mau1wurf1977
You can change the MPU401 resource of the AWE to 300 instead of 330. That should fix the issue.
My YouTube channel
Reply 8 of 20, by CryoSID
All Yamaha DS-XG sound cards have genuine OPL3.
Reply 9 of 20, by jwt27
YMF71x works fine in Windows, and doesn't even require drivers under Win2K/XP (WDM drivers are included in OS). You'll get a nice OPL3 midi driver too which rocks in Age of Empires 😀
But as Maulwurf said, you'll miss out on proprietary features like EAX/A3D. If you're after these you're better off getting a YMF74x, 75x, or Vortex2. The PCI Yamaha cards should have a "genuine" OPL3, but it probably runs at 48k or 44.1k sample rate.
Reply 10 of 20, by sliderider
CryoSID wrote:
You should go with a YMF740, YMF744 or YMF754 sound card because not only they have A3D 1.0 and EAX 1.0 support but also a genuine OPL3. The drivers can be downloaded at http://www.yamaha.co.jp/english/product/lsi/download
I have a YMF724 card. Do you know the official driver download page for that?
Reply 11 of 20, by jwt27
http://www.yamaha.co.jp/english/product/lsi/download ...?
Reply 12 of 20, by Stojke
Can i get YMF754 to work under DOS 6.22 with out Windows?
OPL3 on my YMF718 is very nice, but one channel is damaged and sounds horrible.
Reply 13 of 20, by jwt27
Did you check that cap I told you about yet? 😉
Reply 14 of 20, by Stojke
I didn't yet. I am keeping that for when i get access to better tools. The only soldering iron i have is an 40W one from soviet russia 😀
Reply 15 of 20, by CryoSID
Yes, but you need to install the DOS utility under Windows first.
Reply 16 of 20, by swaaye
DirectX 2/3 actually come with a bunch of drivers for popular ISA sound cards. Windows 98 also has many included. And some companies did release Directsound compatible drivers themselves. So usually Directsound games will work fine on ISA sound cards.
The AWE series Directsound driver allows wavetable RAM to be used for Directsound static buffers. Static buffers let you store sound samples in the card's RAM (similar to a MIDI patch set). I don't know if many (or any) games did much with this.
Reply 17 of 20, by Stojke
Cant i take installed files and copy into DOS?
Reply 18 of 20, by gerwin
You can,
For DOS emulation a YMF-724 / DS-XG sound card is best at home on a i440BX mainboard, connected to the SB-Link header with a cable.
Reply 19 of 20, by Stojke
I think my Vectra doesn't have an SB Header at all. It has that thing for graphics card. It is an Hoontech iPhone YMF754.
Than again, i could use PAS16 or CT1690 for OPL3... But still, YMF718 sounds so vivid compared them.
