First post, by undermark5
I have the config file set to allow IPX (ipx=true) and then open dosbox then try to run ipxnet serverstart and then it just goes back to Z:> waiting for input after displaying "IPX Tunneling utility for DosBox". I'm running dosbox0.74 on Kubuntu (variant of Ubuntu but the same kernel which is based off of the debian kernel) and actually the very same thing goes for when I try to run it in Windows 7 Ultimate (both OS's are 64 bit) do I like need to install something else or no it should work out of the box (well minus changing the .conf) and I'm just failing miserably at dosbox. I want to get this working so I can play MOO2 over the LAN. So if anybody out there can help me that would be great.
