First post, by jpcoulon
PSPICE has its own spead diagnostic tool. With DOSBOX on windows 8 it says info_dosbox.txt and on XP it says info_xp.txt.
What are the best settings in the config file for me?
    info_XP.txt
    850 Bytes
    63 downloads
    info_dosbox.txt
    923 Bytes
    54 downloads
Jean-Pierre Coulon
Reply 1 of 2, by Jorpho
Please don't start multiple threads.
PSPICE
If DOSBox is behaving differently in your Windows 8 installation than it is in your Windows XP installation, then you are using different configuration files. DOSBox should behave the same way under both Windows 8 and Windows XP as long as you use the same DOSBox.conf.
Reply 2 of 2, by jpcoulon
Sorry, but "not working" and "working slowly" are *two* topics! 😀
If DOSBox is behaving differently in your Windows 8 installation than it is in your Windows XP installation [...]
PSPICE works perfectly in XP *without* DOSBox.
Jean-Pierre Coulon
