Socket 754 Curiosity Build
First post, by Half-Saint
I decided to call this build Curiosity because I never owned an Athlon 64 and this thread got me thinking:
Advice on upgrading a socket A platform.
I threw together a DFI Lanparty UT nF3 250Gb, Athlon 64 3000+, 2GB of PC3200 RAM, a GeForce 6600GT and a modern 320GB laptop hard drive.
Currently installing Windows 7 then I'll report back on how it goes 😉
Reply 1 of 25, by Half-Saint
Took some time to install Windows 7 but once installed it's quite snappy. Browsing is reasonably fast but YouTube is choppy even at 360p. I only tried it with IE because I didn't have time for anything else. Will do some more testing on Monday.
One thing to do is download proper nVidia drivers and replace Microsoft drivers for the 6600GT.
Reply 2 of 25, by Nahkri
Half-Saint wrote:
Curiosity because I never owned an Athlon 64 and this thread got me thinking:)
Same reason why i upgraded my socket A to 939,back in 2007 i jumped from socket A to 775,bypassing the Ahtlon 64 era,so now i wanted to have 1.
Reply 3 of 25, by obobskivich
Single-core Athlon64 should not struggle with SD content *at all*, but the lack of drivers may be a problem - also if you haven't updated IE/Flash/etc that can have a detrimental effect. "Legitimate" 1080p (that is, from a Blu-ray or HD-DVD) may consume its resources and limit multi-tasking, but it should play them at least - lower bitrate stuff shouldn't struggle as much; I know my AthlonXP 3000+ (which is much slower than the Athlon64 3000+) could do 720p (and nothing else), or DVD + very good multi-tasking. My Athlon64 X2 3800+ had no issues with 1080p and multi-tasking (like browsing the web).
Anyways - very nice part selection, very much the "ideal" for a gaming computer from that era, and it should be very competent for a very wide variety of games, or just as a nice browser box. 😀
Reply 4 of 25, by leileilol
I would blame Flash. There was once a time when Athlon64s played Youtube no problem.
Reply 5 of 25, by Standard Def Steve
Try disabling Aero. I've noticed that it take a huge bite out of performance with old WDDM 1.0 video cards.
Also, if you're on Chrome, try FireFox or IE in full screen mode. Seems to help performance with older rigs. Edit: Never mind, I guess I should learn to read.
The CPU itself has more than enough power for YT at 360p. A much slower Athlon XP 2800+ can still do 360 and even 480p at 30fps. Edit: Under WinXP - haven't tried Win7 on it.
"A little sign-in here, a touch of WiFi there..."
Reply 6 of 25, by kithylin
update your video drivers to load nvidia drivers, and try either firefox (latest release) or chrome (latest release) and update to the latest flash. If you do all of this then it should enable gpu acceleration for flash in win7, which will significantly drop cpu usage and should enable you to play higher content without issues.
Reply 7 of 25, by obobskivich
Flash GPU acceleration on an AGP GeForce 6600? 😕
It doesn't appear on the nVidia HCL:
http://www.nvidia.com/object/gpus_supporting_adobeflash.html
And more about Flash GPU:
http://www.tomshardware.com/reviews/adobe-fla … ion,2805-4.html
It's gonna lay solely on the Athlon64's shoulders here; but 360p should not even be a discussion about "will it run" or "I need a GPU to run it" and so on, unless YT/Adobe has done something magnificent to turn silly low-bitrate content into something more demanding than full-rate DVD. 😵
Reply 8 of 25, by kithylin
I didn't think flash was vendor specific. I was under the impression that flash just runs GPU acceleration on any video card in any system as long as you have 3d Accelerated video drivers loaded and the card can do 2D acceleration, just like any other standard Direct2D / Direct3D application.. as long as driver support is installed, it runs? I might be wrong though.
Reply 9 of 25, by obobskivich
Oh no - nothing at all like that. Flash is not a DirectX application nor is it capable of being rendered entirely on the GPU (see the Tom's guide for Adobe's explanation of that) - Flash using h.264 video can lean on the GPU to decode the h.264 component if the GPU is capable of it, which from nVidia requires a GeForce 8 or higher. GeForce FX through GeForce 7 have varying degrees of partial video acceleration across varying models (there is no universal featureset among them), however in general they require specific software to unlock those features, and the performance benefits may not be substantial.
In general video acceleration across the board isn't that generic - it requires specific hardware support and software that can take advantage of that hardware. Very modern PCIe cards tend to be able to do a number of things to help out CPUs, however modern CPUs are generally powerful as to not require such capabilities. See the links I provided for more information.
Reply 10 of 25, by Half-Saint
I clearly remember playing YT videos just fine on an Athlon XP-M 2400+. 720p didn't really work all that well but I thought that was more due to my slow internet connection. That's why I somehow expected YT wouldn't be such a problem for a next-gen CPU. When did it become such a hog?
Also... I'm impressed that Win7 is running so well on a 10 years old CPU 😀
Reply 11 of 25, by Standard Def Steve
Flash really started to gain weight when Adobe took over, and it's been getting slower every few months since then. Just a year ago a fast PIII could handle 480p with "only" ~80% CPU usage. Today, that same machine can only push 16fps in 480p. 360p, while smooth, almost completely monopolizes the CPU.
Heck, I've seen brand new AMD E1 dual-core laptops (which I believe run at around 1.5GHz) struggle with Flash video in Chrome. Chrome for some bizarre reason refuses to use hardware accelerated Flash decode, no matter what GPU is installed.
Among other things, HTML5 was supposed to save us from Flash's poor performance, but its video playback appears to be just as CPU-intensive on systems without modern video cards.
Reply 12 of 25, by obobskivich
My XP-M 2400 at 2GHz could do 720p mkv files (and nothing else mind you 🤣); gotta love Adobe bloatware. 😲
Reply 13 of 25, by ODwilly
I was using a 2.4ghz Athlon 64 754 rig with Windows 7 for a while. It had 1.5gb of ddr400 (refused to boot with dual 1gb sticks, thanks VIA)
Reply 14 of 25, by Half-Saint
OK, here's a long shot... could an existing installation of Flash somehow be tweaked to run better?
Reply 15 of 25, by leileilol
Yeah, by installing an earlier Flash 10 or 9.
Reply 16 of 25, by obobskivich
This should work for MOST applications, but IME YouTube will cause the browser to CTD if you aren't running the latest or near-latest version of Flash. 😵
Reply 18 of 25, by obobskivich
Can't speak to all 300+ on the list, but mostly popular games from ~2007 or earlier shouldn't be a problem, although some of them shouldn't be expected to run with everything at maximum - for example Oblivion won't run with everything turned up to the maximum at high resolutions, but it should be fine at normal resolutions and with normal settings.
Reply 19 of 25, by Half-Saint
Just found a Point of View GeForce 6800GT 256MB in the dumpster in good working order. Not sure, if I'm gonna use it because the noise coming from its fan is awful! What's interesting to me is that it has two molex connectors for power.
Also found a case for this build so stay tuned for pics 😉
