First post, by eggbertx
I'm having an issue with Quake causing DOSBox to segfault a few seconds after starting. It'll either segfault shortly after starting the program, or shortly after starting a new game. I'm running Arch Linux on an x86_64 system with 4GB RAM
Here is the output in the terminal
CONFIG:Loading primary settings from config file /home/eggbertx/.dosbox/dosbox-0.74.confMIXER:Got different values from SDL: freq 44100, blocksize 940ALSA:Can't subscribe to MIDI port (65:0) nor (17:0)MIDI:Opened device:noneALSA lib pcm.c:7843:(snd_pcm_recover) underrun occurredDOSBox switched to max cycles, because of the setting: cycles=auto. If the game runs too fast try a fixed cycles amount in DOSBox's options.zsh: segmentation fault (core dumped) dosbox
