Which Sound Blaster Pro do you have? From the link the original Sound Blaster Pro (1.0) has install disks that are either 360KB or 720KB in size. The Sound Blaster Pro 2.0 disks have install disks that are 1.44MB in size. You need to pick the right set of drivers for the card.
The volume labels for the Sound Blaster Pro (1.0) disks must be as follows :
SBPRO DISK1
SBPRO DISK2
SBPRO DISK3 (if using 360KB files)
SBPRO DISK4 (if using 360KB files)
The volume labels for the Sound Blaster Pro 2.0 disks must be as follows :
INSTALL
APPLICATION
ACCESSORIES
Note that no floppy disk volume label can be more than 11 characters long. DOS file and directory names can have no more than 8 characters for the name plus 3 characters for the extension. Unline file and directories, spaces and periods are legal in a disk volume label, but you don't get more characters for extensions.
