First post, by 386_junkie
Hello!
New to these forums and thought to post my first hardware issue.
I bought these two motherboards from ebay (2 of many!) sometime ago and they came with no manuals or indication of manufacturer and have since been attempting to modify the cache settings and FSB frequency of the boards, unsuccessfully. They both have the Opti chipset, one a 495XLC and the other, a 495SX.
I have already done some searching on google and found some board variants which are similar... but not quite jumper compatible.
I was hoping with the experience and good eye's of the Vogon members that I may find more information and possibly if i'm luck, jumper settings information. If anyone does recognize these boards or could share any information, I would apprecaite it greatly.
Thanks and regards
    55.99 KiB
    83.76 KiB
Reply 1 of 6, by Stiletto
The Guide -> DOS is for the discussion of how to get DOS games running on newer systems, not for the hardware itself.
Moved to Marvin, the correct subforum (no worries)
do the Fandango!" - Queen
Stiletto
Reply 2 of 6, by 386_junkie
Hi Stiletto,
Thanks for doing that... i'm still getting used to the different forums of the site.
Regards
Reply 3 of 6, by Mau1wurf1977
Why are the batteries still on the boards? 🤣
My YouTube channel
Reply 5 of 6, by 386_junkie
Guys,
Thanks for your replies!
Yea the batteries were removed as soon as the boards arrived. Sorry about the pictures, they are unfortunately the only pictures I have at the moment (old ebay ones!) as i'm at work, away from home... soon to be returning where I plan on working on a new build, using one of these boards.
The closest I seem to find looking on my own is this Auva / J-Mark board: -
http://museum.ttrk.ee/th99/m/S-T/31375.htm
also here... http://motherboards.mbarron.net/models/486vlb3/opti495.html
For a while I thought they were DataExpert until I stumbled across a couple schematics online and the 3 VLB's were at the edge of the board instead of the centre like these.
I know the jumpers are difficult to see, though do they resemble any boards you may have seen?
Thanks for your help
Reply 6 of 6, by 386_junkie
btw... Mau1wurf1977
I just put 2 and 2 together... You're the guy that made the video on Youtube comparing the LAPC-I and DB50XG on a bunch of games. Was a really good video and instrumental (excuse the pun!) in my decision making... so thanks!
