First post, by Holering
Live Value! Sbpro 98se dosbox emulation has started acting up since changing wdm versions. Upgraded WDM driver from 09-2001 to 03-2002 and got a horrible static-buzzing noise with Primal Rage and Mortal Kombat 1 CD. Reverted back to 09-13-2001 WDM and the noise still exists! What exactly did the newer WDM drivers do to screw things up? Reminds me of vdmsound in XP. Found a wavemix.ini and ctsynwdm.INI in windows folder bit changing settings has no effect (changed sbirq and waveblock settings). I'd use the vxd drivers but those bluescreen with sb16 emulation no matter what (am3 mobo has some nmi-ddma issue I think).
Any help would be greatly appreciated!
