First post, by retrofanatic
Just picked this up yesterday as posted in 'Bought these (retro) hardware today' topic and thought I would start a new topic for it to commemorate my 300th post 😀 .
It is a COMPAQ Proliant 2500 in 'tower form' (one can purchase a rackmount kit to make it part of a rackmount system and mount it sideways).
Some pics:
336.66 KiB
377.7 KiB
499.87 KiB
383.26 KiB
281.14 KiB
This is a very heavy metal (and some plastic 🤣 ) monster...it turned out to be in nice shape after some gentle scrubbing and cleaning. The only thing I need to fix is the latch that holds the front translucent drive bay door closed. It is a pretty cool design as it essentially a two-part motherboard that plugs into a kind of backplane connector that has the SCSI and other connectors on it (i.e. fan, power, etc.).
Each motherboard part can be pulled out in it's tray by unlocking a latch in the back of the unit and pulling out the tray to reveal the ISA/PCI expansion slots on the upper board and the CPU and RAM on the lower board (that hangs upsidedown).
It includes:
PCI and EISA Slots
- Dual Pentium Pro Slots (Slot 😎
- Pentium Pro 200 CPU installed (I believe it is the 512k cache version??-not sure yet)
- up to 1GB of ECC memory (mine came with 640MB - including 2x50ns 256MB RAM modules - I wonder if it takes advantage of the speedy 50ns rating?)
- Integrated Wide-Ultra SCSI-3 Controller (40 MB/s)
- OS Support: DOS, Microsoft Windows NT, Novell NetWare, SCO UnixWare and OpenServer, IBM OS/2, Sun Solaris, and Banyan VINES operating systems (Can support Win 9x as well)
Since yesterday I have added:
- S3 PCI card (with VRAM expansion module for a total of 64MB) - used in lieu of the onboard video
- integrated controller is Cirrus Logic CL-54M30 with 1MB Video Memory - (all I needed to do to use PCI video instead was to flip a small dip switch and onboard video is disabled to allow PCI or ISA video to work instead)
- Yamaha YMF-71x ISA sound card
- Voodoo1 4MB Diamond Monster (thinking of using two of my Voodoo II 8MB cards in SLI instead)
- 10,000RPM SCSI Hard Drive (non-hot swappable - for now)
I have installed DOS 7.10 on the SCSI Hard Drive I added after running the proprietary SmartStart setup program from Compaq(HP)....there is no BIOS accessible on this board without booting from this disk first. As a quick test, I tried running Star Wars:Dark forces on it and it ran perfect. It seems to load everything much faster than my Pentium 166MMX DOS setup and sound works fine using my YMF-71x card (only have tested Dark Forces)...so I am happy so far...but I have a lot of testing I would like to do still when I can make some time to do so.
I am thinking that I may want to keep this system as a fast DOS only system until I get another voltage regulator to be able to install a second CPU, at which time I may opt to install Windows NT on another partition to take advantage of dual processing (even though i know there are limited games made to work well on NT).
Comments are welcome especially regarding....
- what O/S I should be running?
- does anyone else have a similar system? If so, what are you using it for? How do you like using it?
- what video card combo will work better than what I have in it so far?
- what games would be good to run on sucha system?
Reply 1 of 10, by obobskivich
Overall it's a very cool looking system - I like the "slot down" mounting for the expansion cards, and how the optical drives are mounted. Very cool case!
It's tough with a machine like this with NT vs 9x because it probably won't do so hot with Windows 2000; I'd say DOS or 9x and then put NT or *nix on another partition for when you want to play around with SMP (if you end up adding another CPU that is). If you never touch SMP, just go 9x or keep it with DOS and let it ride. If it supports the "black chips" I'd go with a pair of those just for grins, I don't recall them being too expensive any more, just not very common (Pentium Pros have fallen victim to gold salvaging over recent years). Like this combo lot: http://www.ebay.com/itm/Pentium-Pro-200Mhz-1M … =item27e37d1b0e
As far as similar machines, I've worked on a few ProLiants over the years, never a Pentium Pro though. The best I remember was a dual Pentium III (it only had one CPU mounted), and it was fairly similar looking pedestal to this one, and an absolute darling to deal with. Everything just worked the way it was supposed, and it was easy to take apart and put back together. The worst was a QP Xeon II rackmount that had four CPUs on cards, two RAM expansion cards, PCI riser cards, multiple PSU mounts (and a card for that), etc etc - everything was setup with interlock sensors and if it wasn't fitted "just so" it would throw up a ton of errors and refuse to boot. It also had this awful management/instrumentation controller that was spidered into everything, the idea behind it was that it could "phone home" (to its owner/operator) if something bad happened to it in the datacenter/rack while nobody was around, but it ended up just being more grief than it was worth (the thing had its own dedicated modem, among other things). I also know that system wasn't very well cared for - it was a workhorse and it was treated as such. I'm guessing if it had been better cared for, it wouldnt've been as finicky, but I honestly don't know.
As far as graphics goes, I'm guessing anything beyond the Voodoo SLI is going to be limited by the Pentium Pro (either the lack of MMX or the fact that it's "only" a 200MHz CPU) - you could probably stick a PCI Rage or TNT2 or what-have-you in there as a quick'n'dirty all-in-one solution that'd provide good performance. If you really wanted to go nuts, and don't mind spending a reasonable amount of time (and potentially money), something like a Symmetric GLyder/MP would probably be "era accurate" for a monster PPro workstation.
That'd be this card:
https://web.archive.org/web/19980615014402/ht … roducts/mp.html
No idea what it'd be like for games, but it'd certainly be cool. 😎
Reply 2 of 10, by retrofanatic
Thanks once again for some great info....I think that I may just go the pure dos route for the most part...I may just keep the s3 and the voodoo1 in there for now...you're right...anything faster than V2 sli would probably just be under utilized with the pro 200 mhz cpu. I may also try win 98 to see how well some games perform...I have a feeling that some early flight sims I like may run nicely on a pentium pro. I do have a faster pII 400 system but I think this ppro will hold up to be more compatible with a lot of later dos games.
Also...along the lines of reliability that you touch upon...I think this system is solid with chips everywhere saying made in Japan and USA instead of just China and Taiwan. ..There's plenty in this system from chassis to motherboard and even the power supply to suggest a very solidly built piece of hardware. I'm looking forward to doing some benchmarking as soon as I set it all up to see what it can really do....I know there are limitations with ppro systems but I think it will fly in dos for the most part...I'm just concerned about compatibility...but we'll see.
Reply 3 of 10, by obobskivich
Something else I remembered/thought of - there's a Pentium II Overdrive module for Socket 8. I doubt they support SMP, but if you're just keeping it with DOS or 9x, that might be a better consideration as an upgrade for the CPU than going with fancier Pentium Pro models.
Reply 4 of 10, by retrofanatic
Yes the owner manual does mention the overdrive being compatible and I think SMP is supported, but it is hard to find those overdrive cpu's and they are quite expensive when I do see them come up for sale. I think the PPRO 200 will be fast enough for now, but I think I will be keeping an eye out for the overdrive just in case I find one at a good price.
Reply 5 of 10, by obobskivich
Should've mentioned that: I have absolutely no idea what pricing/availability is like, I just remembered the chips existed. 😊 Did not know that SMP was possible - that's neat. I wonder if one could stack six of them in one of those ALR monsters... 🤣
Reply 7 of 10, by swampfox
Oh my....
This is a beautiful system. I would love to have something like this.
You should probably go with Windows NT 4 Workstation. DOS and 9x won't take full advantage of the hardware you have.
Sure, you won't have much in terms of Direct3D acceleration (forget about the unofficial DX5 patch, it doesn't really work), but you will still have full OpenGL and Glide at your disposal.
Another downside to NT is shoddy 16-bit (Win3x application) and DOS support. Suppose you could have a seperate partition or drive with 9x on it, though.
But the stability and performance in the applications and games that take advantage of this hardware would be worth it.
Lets say you were going to use this for actual server tasks. NT 4 is good, but you might consider a UNIX-like system, such as Solaris, GNU/Linux, or a BSD distribution.
As a server these days, although neat, consumes waaayyy more power than even the earliest Xeon systems, and a long uptime will drive your electricity bill up like crazy. So probably not a good idea, at least not full-time. Perhaps just for a bit for fun.
Swampfox's Computing - Google+ and YouTube: https://plus.google.com/108854180391399268575
Reply 9 of 10, by retrofanatic
swampfox wrote:
Oh my.... This is a beautiful system. I would love to have something like this. […]
Oh my....
ya it will be more for using only once in a while...I won't have it running too long for the most part so power consumption won't be an issue. I am leaning toward using windows NT more and more especially if I do end up using this system in smp. ..no matter what I do I will for sure keep a separate partition with dos and maybe win9x.
Thanks for the advice on DX5. ..I most likely will not try to run anything that uses anything above DX5 anyways...I prefer to run the oldest compatible games as fast a possible but without sacrificing compatibility.
Reply 10 of 10, by Unknown_K
obobskivich wrote:
Unknown_K wrote:
PPro Overdives support 2 CPUs in SMP.
Learn something new everyday. Thanks for the info! 😀
I have a pair on a PR440FX Intel board, they are a nice speed improvement over the stock 200Mhz 256K cache PPRo's. For 4/6 way servers you are stuck.
