First post, by Shalmendo
I am running Dosbox 0.74 and am attempting to run KiloBlaster but the kilo.bat file keeps quitting out with the message "illeagal command: kfilea"
I looked into the bat and found the following:
@echo off
cls
kfilea %1 %2 %3
:Very important -- do not modify or remove this file,
:it is VITAL to starting the game properly.
The files are from a downloaded zip, and I checked several different zips from different sources to make sure I wasn't missing a file or anything, but they're all identical. The dosbox compatibility page claims full support under 0.73 (which I tried as well, with the same results). I have been able to run many other games successfully so I don't know what the deal is. I haven't heavily modified my config, except to try and add gravis support. I will gladly post my entire config here if necessary.
Is there some alternative trick to getting it to run? It looks like it's trying to use a streamed means of running all the .exes one after the other (They're all there) but the method it's using is tripping DosBox up. I've tried searching everywhere for this particular problem but I haven't found anything particularly useful.
