First post, by guniu
So I have a small issue with Mega-Lo-Mania. There is this option to delete current design in Blueprint menu:
Info says to press both mouse buttons to delete it and it's simply not working. I don't remember if this worked in the original environment or not. Just curious if this can be Dosbox issue or maybe it's only me that is having this problem? Can anyone confirm it?
I'm using DOSBox 0.74, Windows 7, CPU i7-2600k @4.6GHz
