First post, by badmojo
I’m using a Chaintech 486SPM (486 PCI motherboard) which had some minor acid damage. I didn’t have to fix the damage, just clean it up, and I’m using an external battery on the provided header. The BIOS remembers all the settings, date, HDD – everything except the time, which I’ve set a few times but it slowly gets out of wack. Otherwise this board works 100% after weeks of daily use.
What could possibly cause that? It remembers the date, but it’s like the clock is simply running slowly.
Reply 1 of 13, by RacoonRider
Hello, friend! Can it be that one of the traces is damaged to the point where there is still contact, yet the resistance is significant? Is the battery seated well? I would check the voltage on the other side of the board between battery contacts first.
Reply 4 of 13, by DonutKing
What sort of external battery are you using?
All my computers seem to drift out of time, even back in the day I remember having to reset the time on my DOS machine.
Reply 6 of 13, by badmojo
Thanks for the responses! I'll check the traces again but in my mind the clock would either be working or not if resistance was an issue?
I'm using a brand new coin battery, attached to the external motherboard header via a home made speaker wire / battery holder setup. I use this setup in other PC's without issue but I've used quite a long wire in this case, could that be a problem?
If it was drifting out by a few minutes a day then I wouldn't even have noticed, but it's losing a lot of time, like 8 hours in a 24 hour period. This of course isn't causing any problems, I just play games on this thing, but I'd like to fix it all the same.
Reply 7 of 13, by badmojo
RacoonRider wrote:
Off topic: I keep misreading the title "System shock issue on a Chaintech 486SPM"
I've updated the title for ya 🤣
Reply 8 of 13, by Maeslin
The battery doesn't actually do a thing when the computer is running. Does the clock drift when the computer is on or only when it's turned off? That's a ridiculous amount of drift, might indicate a bad crystal if the RTC on the motherboard uses an external one.
Reply 9 of 13, by obobskivich
Yeah, 8 hours is pretty dramatic. Agreed on watching what it does if the machine is left on - can you leave it powered up for 24 hours straight and observe what it does?
Reply 10 of 13, by badmojo
OK that's a good idea, thanks guys. I'll report back.
Reply 11 of 13, by SquallStrife
IIRC, those external battery headers are designed for a 3.6v battery, coin cells are only 3v. May have something to do with it.
Check the datasheet for the mobo's RTC chip.
Reply 12 of 13, by JaNoZ
I had some boards with battery leakage that caused the traces to get high in resistance, you have to remove the coating and corrosion with sharp knife and a glass brush and put solder on it and remove again with solder wick to brush away the oxidation still there.
And then resolder the path again, some broken parts can be filled with a small wire out of a cable.
Finishing up with a coating pen to prevent contact with air or conductive parts and keep it from corroding by humidity.
Then youre probably good to go.
Reply 13 of 13, by badmojo
Better late than never, I can confirm that you're correct. I switched to a 3.6v battery and the clock stays set.
Thanks!
