Reply 12640 of 27529, by imendit
Mister Xiado, tried that, still. Works fine with an ISA drive controller on the same motherboard. I'm limited by PCI slots on the motherboard, I can always scrap the printer port. I have another identical board, but it's already complete in a case running fine. But I'm thinking of putting a socket 5 motherboard with 4 PCI slots, also so that it can better utilise the Voodoo card.
SpectriaForce, have a look at the photo below.
The alloy piece is from a hardware store, aluminium flat bar, 40mm by as much as you need long, by 3mm thick. Cut it to 15.4mm and remove the burrs. I guesstimated where the keyboard hole goes, even when I measure it, I still get it off by a few mm's. I use 6mm drill bit to pilot the hole then get it to 22mm with the special bit. Works great and doesn't leave any burrs. As for the bracket (blank i/o plate on eBay), I use a 22mm hole saw and finish it off with a round file. Scuff the surfaces where the glue will go, leave it in the vice for a day for it to cure. Originally, the alloy piece was for safety, then I noticed it actually looked really nice.
I should make a video one day...
