First post, by batmreload
Was just curious if anybody's experienced sound problems with the sb line
of cards using 16-bit dma, and if so, how they solved it
For example, I have a Tyan S1854 Slot1/Socket 370. Its a decent board otherwise, Takes a
P3 1ghz, and has one ISA slot. Its based around a VIA chipset (of which ive heard mixed results
over the years)
System is fairly stable, yet any attempt so far to use an sb16/awe32 results in horrendous nosies
(pops and clicks) whenever the high dma channel is used. (EDIT: High dma on the ISA bus)
Again, was wondering if anybody looked further into the issue and determined if it had been the cpu,memory,
or the chipset itself that turned out to be causing the woes.
I'm about to swap out the mobo with an identical ,but new one hoping it was something that got
damaged in the 6 years its been in use since i bought it.
My philosophy when building retro systems is have an identical spare of everything but the case 😊
Reply 1 of 5, by orcish75
Your ISA bus might be clocked too high. Check your BIOS settings if you can change it. Usually it should be set to PCICLK/4 (33.33/4=8.33MHz) or if it allows you to set it to an actual value then set it to around the 8.33MHz mark. Go slower if you have to in order to have no distortion in your sound.
Reply 2 of 5, by bjt
It's not a solution, but high DMA isn't actually required unless you want 16-bit/full duplex. The SB16 can playback 16-bit sound using low DMA only.
Reply 3 of 5, by Kahenraz
I've always wondered about this. Has anyone tried to see if they can tell a difference with and without high dma?
Reply 4 of 5, by Harekiet
Rank DOSBox Author
DOSBox Author
I'd imagine 16bit dma being slightly faster in machines that are starved for memory speed.
