dosbox 0.74 and frontend
First post, by theelf
Hi, have a question
I use dosbox in windows with a frontend, MALA
Mala is a generic frontend for emulators, i have many emulators, dosbox is just one more. Run in fullscreen, and hide all windows desktop
For now, my PC was working with dosbox 0.72 pefectly, but today i decide to update a little....
Dosbox up to 0.72, works perfect. In the frontend I select the game, dosbox windnows appears for a second, and then goes to fullscreen, and the game start
But in dosbox 0.74, is impossible to do. In the frontend I select the game, dosbox windows appears for a second, and then nothing... dosbox remains in background. I need to do ALT+TAB manually, to go to dosbox
This happen in Dosbox 0.74, and in the latest SVN
Any ideas?
Thanks
Reply 1 of 4, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
seems like something you have to discuss with the Mala developers (the config stuff changed since 0.72 I think, both location (not the dosbox program folder anymore) and the name of the config - so that might be part of the problem).
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 2 of 4, by theelf
Hi thanks for reply
Well, in my computer, both 0.72 and 0.74 use the same name for config, dosbox.conf, and are in the same dosbox folder. No big differences about this from 72>74
I will ask in mala forum too, but still looking what can be the change in dosbox that make not going to foreground after opening
I tested in others frontends, and happen the same. Dosbox 0.72 after opening goes to fullscreen, and 0.74 don´t. Dosbox open, but remains in background , not came to foregound, until alt+tab
I tested different builds, unofficial ones, from 0.72 and all work OK, and some unofficial 0.74, like Daum build, and same problem from official 0.74
I know is weird stuff, sorry
And sorry my english
Thanks!
Reply 4 of 4, by theelf
Hi, thanks!
Well, my Pentium 3 machine is not good for some frontends, but latest Mala version is from 2013.. not so old, and others frontends I tested, are not too old neither
I use -conf switch, in fact is the way I call for games. I have one config for every game, and in frontend the config to load games "dosbox -conf %1"
Ayways, even if i put the config file in %LocalAppData%\DOSBox, the problem remains same
The problem is random, from 10 times i open a game, maybe 2 or 3 times 0.74 goes to fullscreen correctly, 0.72 always do
