First post, by truth_deleted
The V1 emulation in hardware mode fails glide sdk test# 11, indicating an issue with the framebuffer, possible in the writes. However, a portion of the framebuffer did not fail the test. This issue produced severe artifacts in direct3d6 games and higher, but was apparent in direct3d5 games and even in DOS glide. The attached patch is a workaround to this issue. This is not fully tested yet, but Jedi Knight (d3d mode) has no artifacts with this patch and also the on-screen text is clear to read, unlike without the patch.
This patch is for testing and is specific to V1 hardware emulation at 640x480, although it shouldn't affect dosbox outside of the V1 emulation. I posted here as soon as I had a successful result.
    v1_d3d_workaround.diff
    3.11 KiB
    136 downloads
    V1 hardware emulation patch for d3d games
Reply 1 of 5, by truth_deleted
Verified other direct3d games rendered without artifacts. Also, half-life in opengl mode ran at playable speeds without any artifacts nor instability. Same for UT99 in glide mode. With the improved framebuffer, glide mode seemed to run faster than previously, so the attached image is at medium graphical settings along with dynamic lighting. Not shown, but rogue spear had no artifacts either under d3d mode, but ran slow as expected because of its steeper cpu requirements.
    555.19 KiB
    hl under opengl mode (2)
    452.62 KiB
    hl under opengl mode (1)
    371.26 KiB
    ut99/glide
Reply 3 of 5, by truth_deleted
Thanks for the information. I did previously try, perhaps a few times, its d3d mode prior to opengl. 😀 I think the glide sdk tests are sufficient for my case. Also, I had wondered about the video memory requirements of the software renderer versus the direct3d renderer in similar d3d6 games.
Reply 4 of 5, by truth_deleted
Attached an updated patch (which requires testing). This version does not have a fixed display resolution in a window while in V1 hardware emulation mode. The other resolutions are now available which may be displayed full screen.
    v1_d3d_workaround-2.diff
    3.8 KiB
    115 downloads
    V1 hardware emulation patch for d3d games (version 2)
Reply 5 of 5, by truth_deleted
This updated patch includes improvements to the V1 emulation (courtesy of the mame project).
    v1_d3d_workaround-3.diff
    6.5 KiB
    116 downloads
    V1 hardware emulation patch for d3d games (version 3)
