First post, by Great Hierophant
- l33t
I will be finishing building a Windows 98SE system soon, and I have just over 300 GB of game disc images I would like to access. I much prefer to use images as opposed to physical discs to save wear and tear on both discs and drives and silence the motor noise. I believe Daemon Tools, version 3.47, will work well in Windows 98SE. However, Windows 98SE and the Intel BX chipset were not designed to access hard drives in excess of 128GB (and I know there are workarounds for this).
In the past, I simply mounted the discs remotely over an Ethernet-based 100Mbit network. I would map a network drive and Daemon Tools would happily load discs remotely. However, this was in the days of Windows XP, when Windows 98SE and XP would happily share each other's drives. For Windows 7 and 8, the traffic only wants to work one way, Windows 7 or 8 will happily write to a shared Windows 98 drive, but Windows 98SE cannot access drives on the more modern system.
Any advice would be appreciated.
