awe32 vs sb32pnp
First post, by robertmo
I didn't want to revive this old thread:
Sound Card List
but just wanted to add:
I have got both these ISA cards and the main difference between them is that sb32pnp is not fully awe32 compatible.
sb32pnp doesn't have 512kB of ram so no game is able to load it's own instrument samples into it (though I don't know whether there were such games). Cause of the same reason it is also not able to "emulate 😉" GM, GS and MT32. (it just cannot load those samples:
Synthgm.sbk (34,832)
Synthgs.sbk (577,350)
Synthmt.sbk (62,466) )
Although I was able to load Synthgm.sbk and it emulated GM (I don't understand why)
I can load all these samples when i add two simm modules to the card. So the card is awe32 compatible after adding memory.
Reply 1 of 2, by robertmo
I have found a more serious difference:
awe32 works fine with Tie Fighter floppy
sb32pnp and awe64 don't 😀
edit:
for those cards you need old aweutil.exe (or you won't hear any music)
you also cannot run the game twice or run music test twice, or run game after testing music, cause music hangs up the second time 😉
Reply 2 of 2, by zbiggy
sb32 is not awe32 compatible. sb32 do not have ASP (Advanced Signal Processor) which is available in awe32.
If you get awe32 and throw away ASP processor you will have sb32.
The ASP is sometimes called CSP (Creative Sound Processor).
The ASP (or CSP) was almost never used in games. I found it only in "PC RALLY" game.
ASP can add Qsound pseudo 3D effect. ASP can compress/decompress wave files in hardware. That is all it can do.
It was very expensive and rarely used. That is why Creative thrown it away and renamed card from awe32 to sb32 to sell it cheaper.
awe32 and sb32 have on-board 1MB of GM midi samples. The synthgm.sbk can be used without RAM because it only set patch names to instruments in ROM memory so aweutil or windows can exactly play GM midi music.
The synthgs.sbk and synthmt.sbk needs RAM to work because they add instruments in RAM to ROM bank. Both combined gives you GS or MT-32 compability. The games for MT-32 often uploads instruments to real MT-32, the awe32 in MT-32 compability mode probably can not do that. So emulation will not be real. I did not had MT-32 so can not tell for sure how looks MT-32 compability and quality.
