First post, by Nelinas
I am so happy with the new DOSBox. Finally I can run CCS without having the mouse confined to the upper half of screen.
I met however the problem of not having music/sound effects.
I have the game from The Underdogs, and it is ripped of speech, but the music and sound are there.
I don't know what drivers to choose when running setsound from within DOSBox (running setsound out of it says that all drivers are unsupported).
Can anybody give a suggestion? Thanks.
Reply 1 of 4, by robertmo
On underdog's forum they say it has no sounds too. Only music so choose General MIDI for music, no sound for sound.
Reply 2 of 4, by Nelinas
I did that. I chose "no digital audio" and "general MIDI..." when running setsound.exe within DOSBox.
It didn't help, still no music.
Well, I guess I should be only too grateful that I can have the mouse moving all around the screen and not fuss about music (sigh).
Anyway, if anybody could help, I'd be really happy.
Reply 3 of 4, by robertmo
In the game there is a volume control - so it cannot be set to 0.
You also need to have midi configured in your windows (you should be able to play .mid files in windows).
Reply 4 of 4, by exofreeze
I finally figured this one out. Rename the dig.ini file to something else. Run setsound and set it to no midi or digital sound. run ccs, restart your current game - and there you go, midi music starts.
