First post, by CHiLL72
Yesterday evening I noticed Wing Commander III Heart of the Tiger can now be downloaded for free on Origin. Just thought there may be some of you who'd like to know...
Waveblaster MIDI boards: https://waveblaster.nl - online now!
Reply 3 of 9, by Mau1wurf1977
Ships with DOSBox 0.73 😒
It's got the screen flashes between videos and the tearing.
Also uses a DVD image DATA.DAT just like the GOG.com release.
Easy to extract and play in a newer DOSBox or burn the image to DVD and play it on a DOS machine.
My YouTube channel
Reply 4 of 9, by DracoNihil
Can you actually use DVD's on DOS machines? I never knew that...
― Κυνικός Δράκων
Reply 5 of 9, by Mau1wurf1977
Check it out: https://www.youtube.com/watch?v=t1kD567PuFQ
It's my Wing Commander III (GOG.com Version) DOSBox / MS-DOS Installation and Tweak Guide.
I show how to make the iso, burn it, install and configure the game. The whole works 😀
My YouTube channel
Reply 6 of 9, by leileilol
Win95c's startup disk even has a DVD device driver.
long live PCem
Reply 7 of 9, by AlphaWing
Any advantage over the CD version?
Other then being able to run it from 1 disk?
Reply 9 of 9, by AlphaWing
Having a DVD copy too is nice, I guess.
Thanks for the heads up.
Also the Origin PDF manual, is a scan of the CD manual, after someone put it through the dryer. As just wow are those scans in bad shape, unless they were deliberately Photoshopped to look like that.
